Problem with external CSV import
Israel Dvorsky March 22, 2014
I am trying to import issues from a CSV and i get the following message:
java.io.IOException: Malformed CSV stream. Missing ["] near offset 62 after field 0 on line 169
I am using JIRA 5.0.4
See CSV attached
Thanks! ()
Nic Brough -Adaptavist-
March 22, 2014
The error message you're getting really is telling you what is wrong - there is at least one " mark in your csv that doesn't match up, and is breaking the format.
You'll need to escape the extra " marks in order to import them. I think it's just using "" instead of "
Israel Dvorsky March 23, 2014
How can I find it?
March 23, 2014
The error message tells you what line is failing, although the character reference might not be that helpful - it's often "the next thing I couldn't read" instead of "where you've got something wrong"
I can't attach a CSV file
Nadir MEZIANI
March 22, 2014
there is no file attached.
