Hi everybody,
i'm trying to create a plugin with some javascripts files that will be loaded in create issue pop up screen.
Jira current version is: 5.2.3.
I have found some related question but i didn't manage to find a solution.
In xml file i'm using the following
<web-resource key="test-js" name="javascript"> <dependency>jira.webresources:global-static</dependency> <description>JavaScript</description> <resource name="test.js" type="download" location="/js/test.js" /> <context>jira.create.issue</context> </web-resource>
My javascript file is the following
JIRA.bind(JIRA.Events.NEW_CONTENT_ADDED, function (e,context) { jQuery("#customfield_12300").hide(); });
The problem is that javascript is not loaded at all.
If i use
<context>atl.general</context>
in xml, javascript is loaded.
I don't know if i'm going to use
instead of
will make page loading slower.
Thanks in advance,
Kostas
If you right click and open the create issue link in a new tab, is the javascript getting loaded (while using 'jira.create.issue' context)? I am thinking with the introduction of create issue pop, there might be a change.
Just a thought.
It works that way.
It thought that jira.create.issue would work on pop up create screen.
If i change the .js file is there a way to make it work?
Cheers
Changing javascripts won't help. Just include that in atl.general. Anyway they won't be downloaded everytime, until a complet refresh is done for the pages, else the browser will use the cached js files.
Hi, Could you please tell me what context did you use for the issue transition windows?
I have a similar query, https://answers.atlassian.com/questions/33140376/web-resource-context-for-issue-workflow-transitions.-
Try to use <dependency>com.atlassian.auiplugin:ajs</dependency> instead of jira-webresource:global-static dependency.
