Problem with language (mix of english and french)
Deleted user April 4, 2012
Hi All,
I've just install the download version of JIRA and I have a problem about the language. I configured all the language in English and it remain some french words (please see above an exemple).
Thanks for your help.
Ivan Tse
July 30, 2012
I wanted to let you know that I've found that there was an issue with the english translation pack that I've created a bug for.
https://jira.atlassian.com/browse/TRANS-554
There's a workaround listed in that bug ticket.
Ignacio Cruz Perez
April 29, 2019
Hi All,
I think the fix could be in your "Personal Setting" section.
Check this link: https://confluence.atlassian.com/cloud/set-the-default-language-873871361.html
simplylearn
February 24, 2019
We have just started to use Jira, and this mix language mix of english and Norwegian is the same problem. All are set up to display in English. But still, we see some are in Norwegian. It looks like Jira is not a stable product.
I have read this: https://community.atlassian.com/t5/Jira-discussions/Jira-creates-new-translated-issue-types-depending-on-the-admin/td-p/674689
It looks like Atlassian don't have a solution and don't care. Is this standard with this product? Do so fare doesn't have a good impression in the Jira and how atlassian makes SaaS.
PAULO RENATO DE LARA RODRIGUES January 14, 2019
Hi all!
I have the same problem but with portuguese, my issues types continuos to create in Portuguese even I select only English on installation.
It´s a problem in Jira or I doing something wrong?
Regards
Ivan Tse
July 26, 2012
I was digging through the english language packs and I found french through the language packs.
jira.translation.status.open.name=Ouvertes
jira.translation.status.resolved.desc=Un traitement a \u00E9t\u00E9 effectu\u00E9 et est en attente de v\u00E9rification par le rapporteur. La demande peut ensuite \u00EAtre marqu\u00E9e comme rouverte ou comme ferm\u00E9e.
jira.translation.status.resolved.name=R\u00E9solue
jira.translation.status.inprogress.desc=La demande est en cours de traitement par l''attribution.
jira.translation.status.inprogress.name=En cours
jira.translation.status.reopened.desc=La demande a \u00E9t\u00E9 trait\u00E9e une fois mais le traitement a \u00E9t\u00E9 jug\u00E9 incorrect. La demande peut ensuite \u00EAtre marqu\u00E9e comme attribu\u00E9e ou comme trait\u00E9e.
jira.translation.status.reopened.name=Rouverte
jira.translation.status.assigned.desc=Cette demande a \u00E9t\u00E9 ajout\u00E9e r\u00E9cemment \u00E0 la liste des attributions et elle doit \u00EAtre trait\u00E9e. Une demande se trouvant dans cet \u00E9tat doit \u00EAtre attribu\u00E9e \u00E0 une autre personne ou trait\u00E9e et marqu\u00E9e comme telle.
jira.translation.status.assigned.name=Attribu\u00E9e
jira.translation.status.unassigned.desc=Le demande n''a encore \u00E9t\u00E9 attribu\u00E9e \u00E0 personne. Elle peut l''\u00EAtre \u00E0 partir de cet endroit.
jira.translation.status.unassigned.name=Non attribu\u00E9e
jira.translation.status.closed.desc=La demande est consid\u00E9r\u00E9e comme termin\u00E9e, et le traitement est correct. Une demande ferm\u00E9e peut \u00EAtre rouverte.
jira.translation.status.closed.name=Ferm\u00E9e
jira.translation.status.open.desc=La demande est ouverte et pr\u00EAte \u00E0 \u00EAtre trait\u00E9e par l''attribution.
I think there may be untranslaed pieces in the JIRA 5+ language packs.
Ramiro Pointis
May 22, 2012
You installed in English but it shows in French? That's weird, it would be more 'normal' if it was backwards. From where have you downloaded your Jira setup? Was your Jira 5.0 version in french and changed to english in the update?
If that's the case I'll recommend you to create a new instance with the 5.0.4 in english by default and then do a xml backup restore from the other instance.
Thomas Schlegel
and on the administration menu
It doesn't work. I thing this problem is only on the dashboard
Jacques
May 22, 2012
None of Thomas' suggestions solve the issue. I have the same with a mix of Spanish/English. This happened to me when upgrading JIRA from version 5.0.0 to 5.0.4.
I've even tried to disable to (now default included) Spanish Language plugin, but whatever I do some things remain in Spanish.
It seems like the install/upgrade has replaced the English original with the Spanish version.
Solution is greatly appreciated!! (sending this out there to other people reading this)
thanks,
Jacques.
Thomas Schlegel
Hi Jaques,
I think you should open a call at Atlassian Support: https://support.atlassian.com/
Best regards
Thomas
Adolfo Casari
May 24, 2012
I have the same problem (spanish/english mix in some menus after upgrading to 5.0), raised a ticket about 2 weeks ago.
