×Hello. I wanted to move our Jira Server to the Cloud version. During the migration I get an error that the record cannot be deleted from the database because it does not exist. What can I do?
com.atlassian.activeobjects.internal.ActiveObjectsInitException: bundle [com.atlassian.jira.migration.jira-migration-plugin] at com.atlassian.activeobjects.osgi.TenantAwareActiveObjects$1$1$1.call(TenantAwareActiveObjects.java:95) [?:?] at com.atlassian.activeobjects.osgi.TenantAwareActiveObjects$1$1$1.call(TenantAwareActiveObjects.java:86) [?:?] at com.atlassian.sal.core.executor.ThreadLocalDelegateCallable.call(ThreadLocalDelegateCallable.java:38) [?:?] at java.base/java.util.concurrent.FutureTask.run(Unknown Source) [?:?] at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [?:?] at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [?:?] at java.base/java.lang.Thread.run(Unknown Source) [?:?] Caused by: com.atlassian.activeobjects.internal.ActiveObjectsSqlException: There was a SQL exception thrown by the Active Objects library: Database: - name:MySQL - version:8.0.32 - minor version:0 - major version:8 Driver: - name:MySQL Connector/J - version:mysql-connector-j-8.0.31 (Revision: 0c86fc148d567b62266c2302bdad0f1e7a7e4eba) java.sql.SQLSyntaxErrorException: Can't DROP 'index_ao_6ff49d_inc1106621083'; check that column/key exists at com.atlassian.activeobjects.internal.EntityManagedActiveObjects.migrate(EntityManagedActiveObjects.java:54) [?:?] at com.atlassian.activeobjects.internal.AbstractActiveObjectsFactory.lambda$create$0(AbstractActiveObjectsFactory.java:73) [?:?] at com.atlassian.sal.core.transaction.HostContextTransactionTemplate$1.doInTransaction(HostContextTransactionTemplate.java:21) [?:?] at com.atlassian.jira.DefaultHostContextAccessor.doInTransaction(DefaultHostContextAccessor.java:50) [classes/:?] at jdk.internal.reflect.GeneratedMethodAccessor277.invoke(Unknown Source) [?:?] at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) [?:?] at java.base/java.lang.reflect.Method.invoke(Unknown Source) [?:?] at com.atlassian.plugin.util.ContextClassLoaderSettingInvocationHandler.invoke(ContextClassLoaderSettingInvocationHandler.java:26) [atlassian-plugins-core-5.7.3.jar:?] at com.sun.proxy.$Proxy328.doInTransaction(Unknown Source) [?:?] at jdk.internal.reflect.GeneratedMethodAccessor277.invoke(Unknown Source) [?:?] at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) [?:?] at java.base/java.lang.reflect.Method.invoke(Unknown Source) [?:?] at com.atlassian.plugin.osgi.bridge.external.HostComponentFactoryBean$DynamicServiceInvocationHandler.invoke(HostComponentFactoryBean.java:130) [?:?] at com.sun.proxy.$Proxy328.doInTransaction(Unknown Source) [?:?] at com.atlassian.sal.core.transaction.HostContextTransactionTemplate.execute(HostContextTransactionTemplate.java:18) [?:?] at jdk.internal.reflect.GeneratedMethodAccessor287.invoke(Unknown Source) [?:?] at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) [?:?] at java.base/java.lang.reflect.Method.invoke(Unknown Source) [?:?] at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:344) [spring-aop-5.3.10.jar:5.3.10] at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:56) [?:?] at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:60) [?:?] at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186) [spring-aop-5.3.10.jar:5.3.10] at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:137) [spring-aop-5.3.10.jar:5.3.10] at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:124) [spring-aop-5.3.10.jar:5.3.10] at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186) [spring-aop-5.3.10.jar:5.3.10] at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java:70) [?:?] at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:53) [?:?] at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186) [spring-aop-5.3.10.jar:5.3.10] at org.eclipse.gemini.blueprint.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:57) [?:?] at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186) [spring-aop-5.3.10.jar:5.3.10] at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:137) [spring-aop-5.3.10.jar:5.3.10] at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:124) [spring-aop-5.3.10.jar:5.3.10] at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186) [spring-aop-5.3.10.jar:5.3.10] at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:215) [spring-aop-5.3.10.jar:5.3.10] at com.sun.proxy.$Proxy1362.execute(Unknown Source) [?:?] at com.atlassian.activeobjects.internal.AbstractActiveObjectsFactory.create(AbstractActiveObjectsFactory.java:70) [?:?] at com.atlassian.activeobjects.internal.DelegatingActiveObjectsFactory.create(DelegatingActiveObjectsFactory.java:32) [?:?] at com.atlassian.activeobjects.osgi.TenantAwareActiveObjects$1$1$1.call(TenantAwareActiveObjects.java:91) [?:?] ... 6 more Caused by: java.sql.SQLSyntaxErrorException: Can't DROP 'index_ao_6ff49d_inc1106621083'; check that column/key exists at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:120) [mysql-connector-j-8.0.31.jar:8.0.31] at com.mysql.cj.jdbc.exceptions.SQLExceptionsMapping.translateException(SQLExceptionsMapping.java:122) [mysql-connector-j-8.0.31.jar:8.0.31] at com.mysql.cj.jdbc.StatementImpl.executeUpdateInternal(StatementImpl.java:1334) [mysql-connector-j-8.0.31.jar:8.0.31] at com.mysql.cj.jdbc.StatementImpl.executeLargeUpdate(StatementImpl.java:2084) [mysql-connector-j-8.0.31.jar:8.0.31] at com.mysql.cj.jdbc.StatementImpl.executeUpdate(StatementImpl.java:1245) [mysql-connector-j-8.0.31.jar:8.0.31] at org.apache.commons.dbcp2.DelegatingStatement.executeUpdate(DelegatingStatement.java:234) [commons-dbcp2-2.1.jar:2.1] at org.apache.commons.dbcp2.DelegatingStatement.executeUpdate(DelegatingStatement.java:234) [commons-dbcp2-2.1.jar:2.1] at net.java.ao.DatabaseProvider.executeUpdate(DatabaseProvider.java:2319) [?:?] at net.java.ao.DatabaseProvider.executeUpdateForAction(DatabaseProvider.java:2375) [?:?] at net.java.ao.DatabaseProvider.executeUpdatesForActions(DatabaseProvider.java:2347) [?:?] at net.java.ao.schema.SchemaGenerator.migrate(SchemaGenerator.java:91) [?:?] at net.java.ao.EntityManager.migrate(EntityManager.java:132) [?:?] at com.atlassian.activeobjects.internal.EntityManagedActiveObjects.migrate(EntityManagedActiveObjects.java:52) [?:?] ... 43 more
You are getting that exception from Active Objects which is the persistence layer for Jira apps.
When I check the log provided,
The table starts with AO_6FF49D prefix is related to Jira Cloud Migration Assistant (JCMA) app. I'd suggest raising a ticket to Atlassian support, however, if you have access to the DB, you can check the tables starting with AO_6FF49D. Sometimes, uninstalling the app and (deleting the related tables from the database), and re-installing the app may help.
I believe the best solution is to raise a support ticket.
