Problem with osgi: missing requirement osgi.wiring.package; osgi.wiring.package=com.atlassian.inject
Александр Романов
May 25, 2017
I am trying to compile my plugin. But plugin is not getting enabled and i have this error:
Unresolved constraint in bundle com.atlassian.pl.jgit [114]: Unable to resolve 114.0: missing requirement [114.0] osgi.wiring.package; (osgi.wiring.package=com.atlassian.inject)
I tried other answers from here, but it doesn't work for me.
My pom:
<?xml version="1.0" encoding="UTF-8"?>
<project xmlns="http://maven.apache.org/POM/4.0.0"
         xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
         xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd">
    <modelVersion>4.0.0</modelVersion>
    <groupId>com.atlassian.pl</groupId>
    <artifactId>jgit</artifactId>
    <version>1.0.0-SNAPSHOT</version>
    <organization>
        <name>Example Company</name>
        <url>http://www.example.com/</url>
    </organization>
    <name>jgit</name>
    <description>This is the com.atlassian.pl:jgit plugin for Atlassian JIRA.</description>
    <packaging>atlassian-plugin</packaging>
    <properties>
        <jira.version>7.1.0-QR20151229171111</jira.version>
        <amps.version>6.2.11</amps.version>
        <plugin.testrunner.version>2.0.0</plugin.testrunner.version>
        <atlassian.spring.scanner.version>1.2.13</atlassian.spring.scanner.version>
        <atlassian.plugin.key>${project.groupId}.${project.artifactId}</atlassian.plugin.key>
        <testkit.version>6.3.11</testkit.version>
    </properties>
    <repositories>
        <repository>
            <id>com.atlassian</id>
            <name>Atlassian Repo</name>
            <url>https://maven.atlassian.com/content/repositories/atlassian-public/</url>
        </repository>
    </repositories>
    <dependencies>
        <dependency>
            <groupId>com.atlassian.jira</groupId>
            <artifactId>jira-api</artifactId>
            <version>${jira.version}</version>
            <scope>provided</scope>
        </dependency>
        <dependency>
            <groupId>junit</groupId>
            <artifactId>junit</artifactId>
            <version>4.12</version>
            <scope>test</scope>
        </dependency>
        <dependency>
            <groupId>com.atlassian.plugin</groupId>
            <artifactId>atlassian-spring-scanner-annotation</artifactId>
            <version>${atlassian.spring.scanner.version}</version>
            <scope>compile</scope>
        </dependency>
        <dependency>
            <artifactId>atlassian-spring-scanner-runtime</artifactId>
            <scope>runtime</scope>
        </dependency>
        <dependency>
            <groupId>javax.inject</groupId>
            <artifactId>javax.inject</artifactId>
            <version>1</version>
        </dependency>
        <!--Для работы с гитлабом-->
        <dependency>
            <groupId>org.gitlab</groupId>
            <artifactId>java-gitlab-api</artifactId>
            <version>1.2.8</version>
        </dependency>
        <!--Для мерджинатора-->
        <dependency>
            <artifactId>jira-rest-java-client-api</artifactId>
            <version>4.0.0</version>
        </dependency>
        <dependency>
            <artifactId>jira-rest-java-client-core</artifactId>
        </dependency>
        <dependency>
            <groupId>com.atlassian.fugue</groupId>
            <artifactId>fugue</artifactId>
            <version>2.6.0</version>
        </dependency>
        <!--Для настройки и работы с базой-->
        <dependency>
            <groupId>com.atlassian.activeobjects</groupId>
            <artifactId>activeobjects-plugin</artifactId>
            <version>1.2.3</version>
        </dependency>
        <!--Ключик-->
        <dependency>
            <groupId>com.atlassian.sal</groupId>
            <artifactId>sal-api</artifactId>
        </dependency>
        <dependency>
            <groupId>com.atlassian.templaterenderer</groupId>
            <artifactId>atlassian-template-renderer-api</artifactId>
        </dependency>
        <!--<dependency>-->
            <!--<groupId>org.springframework</groupId>-->
            <!--<artifactId>spring-context</artifactId>-->
            <!--<version>4.1.6.RELEASE</version>-->
            <!--<scope>provided</scope>-->
        <!--</dependency>-->
    </dependencies>
    <dependencyManagement>
        <dependencies>
            <dependency>
                <groupId>com.atlassian.platform</groupId>
                <artifactId>platform</artifactId>
                <version>3.0.0</version>
                <type>pom</type>
                <scope>import</scope>
            </dependency>
            <dependency>
                <artifactId>third-party</artifactId>
                <type>pom</type>
            </dependency>
        </dependencies>
    </dependencyManagement>
    <build>
        <plugins>
            <plugin>
                <groupId>org.apache.maven.plugins</groupId>
                <artifactId>maven-compiler-plugin</artifactId>
                <version>3.6.1</version>
                <configuration>
                    <source>1.8</source>
                    <target>1.8</target>
                </configuration>
            </plugin>
            <plugin>
                <groupId>com.atlassian.maven.plugins</groupId>
                <artifactId>maven-jira-plugin</artifactId>
                <version>${amps.version}</version>
                <extensions>true</extensions>
                <configuration>
                    <productVersion>${jira.version}</productVersion>
                    <productDataVersion>${jira.version}</productDataVersion>
                    <enableQuickReload>true</enableQuickReload>
                    <enableFastdev>false</enableFastdev>
                    <instructions>
                        <Export-Package>
                            com.atlassian.pl.jgit.api,
                        </Export-Package>
                        <Import-Package>
                            org.springframework.osgi.*;resolution:="optional",
                            org.eclipse.gemini.blueprint.*;resolution:="optional",
                            <!--*;version="0";resolution:="optional"-->
                            <!--!org.springframework.osgi.service.exporter.support,-->
                            <!--!org.springframework.osgi.service.importer.support,-->
                            <!--org.eclipse.gemini.blueprint.*;resolution:="optional",-->
                            <!--org.springframework.osgi.*;resolution:="optional",-->
                            <!--com.atlassian.inject;resolution:="optional",-->
                            <!--com.sun.xml.fastinfoset.sax;resolution:="optional",-->
                            <!--com.sun.xml.fastinfoset.stax;resolution:="optional",-->
                            <!--groovy.lang;resolution:="optional",-->
                            <!--groovy.xml;resolution:="optional",-->
                            <!--joptsimple;resolution:="optional",-->
                            <!--net.*;resolution:="optional",-->
                            <!--org.apache.tools.ant;resolution:="optional",-->
                            <!--org.apache.tools.ant.types;resolution:="optional",-->
                        </Import-Package>
                        <Spring-Context>*</Spring-Context>
                        <!--<Embed-Dependency>jira-rest-java-client-core</Embed-Dependency>-->
                    </instructions>
                </configuration>
            </plugin>
            <plugin>
                <artifactId>atlassian-spring-scanner-maven-plugin</artifactId>
                <executions>
                    <execution>
                        <goals>
                            <goal>atlassian-spring-scanner</goal>
                        </goals>
                        <phase>process-classes</phase>
                    </execution>
                </executions>
                <configuration>
                    <scannedDependencies>
                        <dependency>
                            <artifactId>atlassian-spring-scanner-external-jar</artifactId>
                        </dependency>
                    </scannedDependencies>
                    <verbose>false</verbose>
                </configuration>
            </plugin>
        </plugins>
    </build>
</project>
If i change import-package to
I have the 50! errors and Jira startup failed
Durgesh Gupta June 16, 2017
Hi Александр,
Please add this in all our dependencies.
It may resolve your problem.
