I add this Gadget to my JIRA dashboard. I then go to configure it and the list of Projects are not the projects from our installation. It is a list of what looks like to be projects from when the tool was created. How do I get the list of our projects?
Also today when I try and add it I don't get anything in the gadget as far as configuration. I just get a blank aquare on the screen and no edit button.
I miss-stated. It is the list of board names that is not correct. However in the GreenHopper Classic Days Remaining which shows days till Next release the list is correct.
Hi Wayne,
When in edit mode, you can see the board name instead of project name. So, I guess there is no way to configure to show projects lists. Try to run "Lock JIRA and rebuild index" for rebuild the index file to ensure the index file was not corrupted. Hope it helps.
