×Hi,
I'm currently searching for a solution with regards to the following problem.
My question: which function can/should I use to refresh the link section or complete detail view after or during submitting the dialog? Or in other words, what can I do that "F5 will be pushed" after the dialog has been submitted ;-)
I spended a lot of time in try&error without success and thus I would appreciate a solution idea very much!
Thanks in advance!
Best, Günter
Hi @Günter Halmans , I don't know the answer, but you may be able to find some hints here as well: https://community.developer.atlassian.com/
Hi Carlos,
unfortunately, I did not found a solution there...but thank you for this hint!
Best,
Günter
Could you please share the current code you are working with, along with some screenshots of the issue you are facing?
I will review it and provide some feedback.
Thank you and Kind regards,
Ram
Hi Ram,
thank you in advance for giving me your feedback!
Please find enclosed (see below):
I'm looking forward to your ideas!
Best regards,
Günter
1. pic01:
2. pic02:
3. pic03
4.pic04:
5. code:
showLink_Dialog {MultivaluedMap queryParams, String body, HttpServletRequest request ->
// section in which the selection list is generated --> optionString
dialog =
"""<section role="dialog" id="my-own-dialog" class="aui-layer aui-dialog2 aui-dialog2-medium" aria-hidden="true" data-aui-remove-on-hide="true">
<header class="aui-dialog2-header">
<h2 class="aui-dialog2-header-main">Assignment of Issues to current Issue</h2>
</header>
<div class="aui-dialog2-content">
<p>Please select one or multiple Issues from the following list:</p>
<form class="aui">
<select id="select2-example" multiple style="width:80%">
${optionString}
</select>
</form>
</div>
<footer class="aui-dialog2-footer">
<div class="aui-dialog2-footer-actions">
<button id="dialog-close-button" class="aui-button aui-button-link">Cancel</button>
<button id="dialog-submit-button" class="aui-button aui-button-primary">Assign selected Issue(s)</button>
</div>
</footer>
<script>
AJS.\$("#select2-example").auiSelect2({
placeholder:'Select Issue(s)...',
allowClear: true,
width:'resolve',
search:true,
var resultSelection = AJS.\$('#select2-example').on('click', function () {
console.log("Selected values are: " + AJS.\$(this).auiSelect2('val'));
return AJS.\$(this).auiSelect2('val');
(function (\$) {
\$(function () {
AJS.dialog2.on("show", function (e) {
var targetId = e.target.id;
if (targetId == "my-own-dialog") {
var someDialog = AJS.dialog2(e.target);
\$(e.target).find("#dialog-close-button").click(function (e) {
e.preventDefault(); // avoid to execute the actual submit of the form.
someDialog.hide();
someDialog.remove();
\$(e.target).find("#dialog-submit-button").click(function (e) {
var homeUrl = "${baseUrl}/browse/${currentIssueKey}"
const arrayIssues = resultSelection.val().toString().split(",")
for (let i = 0; i < arrayIssues.length; i++) {
var url = "${baseUrl}/rest/api/2/issueLink";
var data = {
"type": {
"name": "CoW"
"inwardIssue": {
"key": "${currentIssueKey}"
"outwardIssue": {
"key": arrayIssues[i]
data = JSON.stringify(data)
let xhr = new XMLHttpRequest();
xhr.open("POST", url);
xhr.setRequestHeader("Accept", "application/json");
xhr.setRequestHeader("Content-Type", "application/json");
xhr.setRequestHeader("X-AUSERNAME", "${user}");
xhr.setRequestHeader("X-Atlassian-Dialog-Control", "DONE");
xhr.onload = () => console.log(xhr.responseText);
xhr.send(data);
}// of for i...
someDialog.hide();
JIRA.trigger(JIRA.Events.REFRESH_ISSUE_PAGE, [JIRA.Issue.getIssueId()]);
})(AJS.\$);
</script>
</section>
Response.ok().type(MediaType.TEXT_HTML).entity(dialog.toString()).build();
