Problem with removing columns for child issues
Davyd Timura
March 9, 2025
here was a problem on the screens: the problem was that in the left site was good type, in the right side i dont know how but my child issue got another view like columns and i cant open it in this tab how to fix it?Screenshot_7.png
Trudy Claspill
Hello @Davyd Timura
The display on the right is an update to the UI that is in the process of being rolled out. Refer to this:
https://community.atlassian.com/forums/Jira-articles/It-s-now-easier-to-configure-fields-for-child-issues/ba-p/2963652
Bruce Banner March 9, 2025
If you're having trouble removing columns for child issues, the issue might be related to permissions, the tool’s default configurations, or the way child issues inherit attributes from parent issues.
In platforms like Jira, Azure DevOps, or similar project management tools, column visibility is often controlled at the board or project level. You may need to check:
  1. Board Configuration: Ensure that column settings allow customization for child issues. Some boards enforce default columns for consistency.
  2. Field Restrictions: Some fields may be required or locked due to workflow rules. Check if the column you're trying to remove is mandatory.
  3. Permissions: If you're working in a shared project, you may need admin rights to modify column visibility.
  4. Hierarchy Settings: Child issues often inherit fields from parent issues, limiting their customizability.
  5. Tele Latino APK is a streaming application that offers a wide selection of live TV channels, movies, and series in Spanish. It provides access to international content, including sports, entertainment, and news, making it a popular choice for Latin American audiences. Download Tele Latino APK.
