Problems between Jira cloud version and Jira server solution!
Mike Kurtze
February 2, 2017
Currently im using JIRA cloud and i would like to import the last backup in my local JIRA Server solution. But i get an error that the cloud solution(Build '72002')  is older than the Jira server(Build '73011') solution! What can i do?
Ankita Sinha
Are you trying restore or project import?
Mike Kurtze
February 3, 2017
Project import! Currently i have my Projects on JIRA Cloud and would like import this to local JIRA Server!
Ankita Sinha
If this is still unresolved, I can offer a solution that you may try. Do a full restore instead of project import on a test JIRA server. Now, do a project import on your local JIRA server from the test JIRA server. This problem would not occur as both the JIRA server would be on same build.
