I'm trying to add a condition on the ''Copy field value to parent'' post fonction.
The condition sould be to copy the field value only if there is a field value. If i don't do that the parent task have a value it will be erased since the value of the child task is empty
i have tryed many things, none works
Thank you in advance!
that's not script runner, i removed the label and added the correct one.
Sorry about that, i thought groovy so script runner. Thanks
I don't think there is a "Copy field value to parent" post function in script runner... maybe you are talking about some other plugin that has some similar ideas and concepts?
