Hi! I managed to export several custom fields using the sintax ${cfname}, however one of the custom fields I need to export has the following name: UEP (single choise).
And I think the parenthesis are causing the problem to export it, cause nothing is printed at the outfut file when I used ${UEP (single choise)}.
How should I write the command line in this case?
Thanks in advandce!
It was just mistyping. As soon as I corrected, it was exported normally.
