Problems with Active Object while exporting and importing
IT-Administration
March 14, 2012
The following things were done recently:
# migration from JIRA 4.3.4 to 4.4.4 (with an upgrade)
# renaming of all (JIRA-internal) users to fit the company standard (using the build-in script from the groovy-runner plugin)
# setting the company LDAP server as primary authentication method
Now all Restore System tries fail with all previous backups (very recent ones as well as very old ones). The Error Message is:
Error importing data: com.atlassian.activeobjects.spi.ActiveObjectsImportExportException: There was an error during import/export with :
•Error importing data: com.atlassian.activeobjects.spi.ActiveObjectsImportExportException: There was an error during import/export with <unknown plugin="">:
the LogFile show:
2012-03-15 17:42:18,133 JiraImportTaskExecutionThread-1 ERROR admin 1062x347x1 tl9lqn 172.21.22.221 /secure/admin/XmlRestore.jspa jira.bc.dataimport.DefaultDataImportService Error importing data: com.atlassian.activeobjects.spi.ActiveObjectsImportExportException: There was an error during import/export with <unknown plugin="">:
at com.atlassian.activeobjects.backup.ImportExportErrorServiceImpl.newImportExportSqlException(ImportExportErrorServiceImpl.java:32)
at com.atlassian.activeobjects.backup.ActiveObjectsDatabaseCleaner.onSqlException(ActiveObjectsDatabaseCleaner.java:104)
at com.atlassian.activeobjects.backup.ActiveObjectsDatabaseCleaner.doCleanup(ActiveObjectsDatabaseCleaner.java:78)
at com.atlassian.activeobjects.backup.ActiveObjectsDatabaseCleaner.cleanup(ActiveObjectsDatabaseCleaner.java:45)
at com.atlassian.activeobjects.backup.ActiveObjectsBackup.clear(ActiveObjectsBackup.java:170)
at com.atlassian.jira.bc.dataimport.DefaultDataImportService.removeActiveObjects(DefaultDataImportService.java:719)
at com.atlassian.jira.bc.dataimport.DefaultDataImportService.performImport(DefaultDataImportService.java:465)
at com.atlassian.jira.bc.dataimport.DefaultDataImportService.doImport(DefaultDataImportService.java:214)
at com.atlassian.jira.web.action.setup.DataImportAsyncCommand.call(DataImportAsyncCommand.java:65)
at com.atlassian.jira.web.action.setup.DataImportAsyncCommand.call(DataImportAsyncCommand.java:28)
at com.atlassian.jira.task.ImportTaskManagerImpl$TaskCallableDecorator.call(ImportTaskManagerImpl.java:147)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager.runForTenant(DefaultMultiTenantManager.java:61)
at com.atlassian.multitenant.juc.MultiTenantExecutors$WrappedRunnable.run(MultiTenantExecutors.java:160)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: org.postgresql.util.PSQLException: FEHLER: Funktion public.ao_60db71_sprint_cl1004036686() existiert nicht
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2102)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1835)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:257)
at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:500)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:374)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeUpdate(AbstractJdbc2Statement.java:302)
at org.apache.commons.dbcp.DelegatingStatement.executeUpdate(DelegatingStatement.java:196)
at com.atlassian.activeobjects.backup.ActiveObjectsDatabaseCleaner.doCleanup(ActiveObjectsDatabaseCleaner.java:74)
... 18 more
5 votes
Ruchi Tandon
March 15, 2012
Hi Sulzer,
I investigated the logs and I see the following error in the logs :
This error is complaining about a function from Greenhopper that it cannot find.
2012-03-15 13:28:38,167 IssueIndexer:thread-1 ERROR admin 768x85x1 zn0msp 172.21.22.221 /secure/admin/XmlRestore.jspa [jira.issue.managers.DefaultCustomFieldManager] Could not load custom field type plugin with key 'com.pyxis.greenhopper.jira:gh-sprint'. Is the plugin present and enabled?
I noticed that Greenhopper is currently disabled on your instance.
2012-03-15 13:28:20,774 JiraImportTaskExecutionThread-1 INFO admin 768x85x1 zn0msp 172.21.22.221 /secure/admin/XmlRestore.jspa [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /opt/jira/plugins/.bundled-plugins/jira-greenhopper-plugin-5.7.4-disabled.jar (1329329356000) created
So basically, the import file contains Greenhopper related data. When you are trying to insert data into the new system, then Jira cannot find the classes related to Greenhopper as its disabled on the instance.
Could you please enable Greenhopper and then try to import the backup. Let em know how you go.
Ruchi
Jeffrey Toce March 16, 2012
Ruchi- you are awesome! I was having the same problem importing existing data during the setup wizard. I kept getting an error about ActiveObjects. You were right- I needed to install Greenhopper first and then do the import.
Thanks!
Ellen Feaheny [AppFusions]
March 16, 2012
Nice nugget!
Thanks!
