Problems with I.E browser on JIRA 6.0
Antonio San Nicolás June 19, 2013
We've updated to JIRA 6.0 and we have problems with the I.E browser. The look or distribution in the browser are wrong and we don't know what to do. I attach a screen where you can see the problem: http://i.imgur.com/CvUwYbL.jpg
C_ Faysal
June 20, 2013
disable the compatibility mode.
this can be done in IE settings and on server side.
in IE:
IE -> tools -> compatibility view settings -> uncheck "Display intranet sites in Compatibility view"
if you're on a Unix Host edit your httpd.conf and add the following at the end of the file:
<IfModule headers_module>
   Header set X-UA-Compatible: IE=Edge
</IfModule>
restart the webserver afterwards.
Renjith Pillai
June 21, 2013
mwesters
June 20, 2013
Hi we are using I.E 9 and have also this issue. Did someone find a solution?
We use I.E 8,9 and 10 and all the users have this problem.
Nic Brough -Adaptavist-
June 19, 2013
What version of IE is it?
There are a couple of known issues with some IE installs that look like that, but unless you're using IE8 or above (and you really shouldn't be using anything lower), there's no fixes I know of.
