Hi All,
I have a simple workflow I've created (To do, In Progress, Done), an issue can move anywhere on the workflow. Resolution though is not required in my workflow and I want it to be. So I created a transition that triggers the Resolution screen and all was well, sort of... Now on my board when a ticket is being moved to the "Done" column, there are two sections of done I can drop the ticket into. How do I make any ticket that moves to done trigger the resolution screen?
Thanks for you time everyone.
If you could show a screenshot of how this isn't working, we might be able to help more!
Both Done and In Progress to Done are transitions. You have two transitions mapped to the DONE column.
You either need to delete the extra transition or you need to add the appropriate screen to both transitions.
