Producing a Jira Plan across multiple Jira projects
Martin Rady June 4, 2024
I'm trying to pull together a Jira Plan for one single Project I'm manging that has work being done across multiple Jira Projects.
Can this be done?
I'd like to show all the work that needs to be done with the dates in the actual Jira issues that are produced by various scrum, admin, business and other teams all of whom use Jira to capture their tasks.
Can I show this plan under a separate coverall Jira Project which represents the overall actual project we are trying to deliver?
2 accepted
great thanks for the quick response.
I think that identifying the Jira issues that are in various Jira projects that are part of an overall actual project is something not currently done in a consistent manner.
Which would you suggest is better:
- something in the description?
- a label in the issue?
- or other mechanism that could be filtered for?
Trudy Claspill
Hello @Martin Rady
Issues exist in one and only one Jira project at a time. The issues that you want to include can't exist in the teams' Projects and another "coverall" Project at the same time.
How do you identify the issues in the other teams' Projects that apply to your "project"? If you can devise a filter that can find all those issues, then you can create a Plan based on the saved filter.
Trudy Claspill
I would not recommend using the Description field because searching based on text and relying on users to enter the correct text is unreliable.
You could use a Label value. Label values are globally available, not case sensitive, and not defined per project, so that is a reasonable option. But again, you are going to be relying on people to add that label when it is appropriate, and not remove it erroneously. You may face some challenges with that.
You are going to need to get buy in from all those teams if you have any hope of the plan being accurate.
Yuliia Hushcha _Reliex_
June 7, 2024
Hi @Martin Rady
Welcome to the community!
I can suggest you ActivityTimeline plugin. You can see cross-project and cross-team timelines in one place.
The dashboard operates on a straightforward drag-and-drop concept. Assign or split tasks to team members directly from the ActivityTimeline. As well as add internal custom events such as vacations, days off, sick leaves, and more, which are not present in Jira timeline.
The app makes it simple to keep track of multiple projects using Special Filters. With timesheet timelines, you can easily keep tabs on how much time you spend on specific tasks and projects.
Check the video to see how easy it can be with the add-on.
If you have any questions, feel free to book the demo session:)
Michał Kowalewski_SolDevelo
June 5, 2024
Hi @Martin Rady
You might consider some applications for capacity planning that are available in the Atlassian marketplace.
One such application is Team Planner - Resource Planning and Capacity Planning, which was developed by SolDevelo, the company I'm working for.
In the app you can create such a plan for a specific project, still having the possibility to display and add tasks from multiple projects.
The application is in the calendar format.
Additionally you can display such estimations like Original Estimate value or Story Points.
Please take a look:
Additionally, the plan can be simultaneously edited by your team, for example, during the planning sessions. There's also a possibility to add days off to your plan for users.
If you have any questions feel free to contact me here. Or if you would like to book a demo to see how our apps work go to this link.
Michał
SolDevelo Team
We have a field we use for Tempo codes 'Initiative Acc' but I don't seem able to filter the plan on it?
