Project Automation - Send Emails to specific Project Roles when an issue is created
I want to send an email to our project test lead, when an issuetype=bug is created.
When I created a Rule for this in the Project (via Project automation), it only allowed me to send the email high level roles that had been setup organisation-wide. I couldnt select roles created fr the Project itself.
Hello @Ollie Guan
How do we vote for this issue? I dont see any links to vote or even provide a comment.
O wow this would be nice!
We have some member as 'project lead', this is the team leader AND a project leader.
So, actually we have two 'leading' roles for a project which we would like to add as smart value in automation.
Also, we have multiple disciplines like HW, SW designers, mechanical (metal) designers, (pre)production, and purchases. People are added to projects based on roles. Addressing project members in automation based on Roles would be very usefull and most of all: UNIVERSAL.
So yes, this feature is VERY usefull.
try this {{issue.project.lead.emailAddress}}
thank you for this, this works perfectly :)
hi @Giorgi Tsitsvidze #
any updates for project roles`?
Hey Andy,
you're right with that. Choosing project roles is currently not supported. However you do have the ability to select single users. So in case you really have a single person for testing, simply enter their E-Mail Adress oder choose their account, and he will be notified.
Alternatively you can try the following workaround:
1. When a bug is created, assign it automatically to that person. This way they should be notified as well, and if not: add them as watcher too!
Hi @Andy Case
I think it's not possible.
In email you can use smart values, and few more (as you said) high level roles that had been setup organisation-wide.
Smart values are only for the triggered issue, there is no option to select any project field.
