Project B is not visible when I try to move an issue from project A
Elif Alverson
I need to move an issue from project A to B. However project B is not visible on the move. I have all the corect permissions based on ; https://confluence.atlassian.com/display/JIRA/Moving+an+Issue.
https://community.atlassian.com/t5/JIRA-questions/New-project-does-not-show-up-on-Move/qaq-p/36444
Any help will be appriciated.
Thank you,
Elif
Maarten Cautreels
April 4, 2017
Hi Elif,
Have you tried a reindex of the project?
Maybe something went bad during the creation of the project which might be resolved by reindexing.
If the project reindex does not work you can try a full reindex of JIRA. Please do take into account that, depending on the size of your instance, this might take a while and could have an impact on the performance.
Best,
Maarten
Elif Alverson
Maarten,
Reindex worked! Thanks much!
