HI Guys,
I'n new to Jira and I can't find a way ton enable COMPONENTS.
I want to group my issues using COMPONENTS but I can't find it. I've already check on the global SCREEN CONFIGURATION and the "components" feature is ENABLED, but when I go to the CUSTOM FIELDS section, it doesn't show.
Hope you can help me.
Jorge
Hi Jorge,
Components is actually a subsection of a project and it isn't a field. You'll need to create at least one component via the Component in Project sidebar.
Feel free to have a read on this documentation: Organizing work with components
Hi Ahmad, Thank you so mucho for your response. The thing is that I don't see all that options that you show me on the screenshot.
I dont know why that options are not shown on my dashboard.
Jorge
If you go into your current Board Setting, What's the location of the board?
Example:
Hi Ahmad,
Thank you so much for your response.
I've just realized that I create my project with the "new" template, not the "CLASSIC" and I found an article which said Atlassian is working on new features and that's why this template doesn't include all I need.
I create a new one with the "classic" template and everything is ok.
Thank you very much for all your help.
Jorge
