×Hi All,
we'd change the email templates: according to the project key, the users would get different links in the email notification hence we have 2 URLs accessing to JIRA.
The code snippet is the following:
#if( PROJECTKEY == "XY")
[ https://zzz.com/browse/${issue.getKey()}?page=${tabpanel-all}]
#else
[ ${baseurl}/browse/${issue.getKey()}?page=${tabpanel-all} ]
#end
Our problem is that we do not find the correct reference for the PROJECTKEY. We tried with this:
$project.Key() but it did not work.
Could you please help?
Thanks in advance,
Rumi
Try $issue.projectObject.key or $issue.getProjectObject().getKey()
You may refer to this page for details https://developer.atlassian.com/display/JIRADEV/Velocity+Context+for+Email+Templates
Yep, as Boris says looks like you can use $issue.getProjectObject().getKey().
However we use $issue.getProject().name for something similar that we do... but looking at the docs, our way might be deprecated and in need of an upgrade but it works for now.
