Project Import on JIRA
Rahul Aich [Nagra]
April 30, 2013
Hi All
I am going to perform project import on production jira instances.
My question is - Is there any issues to perform project import whilst users are using JIRA or is it recommended to use it during a time when there is minimum traffic (ie.e weekends)
Rahul
AlaA
April 30, 2013
Hello Rahul,
Since Project import is not acutually a trivial task to do, it's advisable to perform it during the minimum traffic time. Because you may need to change some configuration in your JIRA. You may refer to the following link for further details on project import:
https://confluence.atlassian.com/display/JIRA/Restoring+a+Project+from+Backup
I hope that helps.
Timothy
April 30, 2013
Better be safe than sorry right? I'd always recommend to either do it during non peak hours or disable JIRA access during this time.
