Project Issues Don't Appear in Agile Backlog
Randy Melder September 13, 2013
I created a project. Added an issue. Created a board. Added the project. Then this happend (see images)
Randy Melder October 2, 2013
ALWAYS create projects with the "AGILE" type or else it's unpredictable where your issues will be allowed to display.
Randy Melder September 15, 2013
Basically, some project types don't show issues in an Agile backlog. So... ALWAYS create projects with the "AGILE" type or else it's unpredictable where your issues will be allowed to display.
Thomas Heidenreich
September 15, 2013
Have you maybe started a sprint which contains the issues?
EDIT:
Just analysed this:
For you need to make sure, that the ToDo Status is in the leftmost column of your board, or else issues won't show up in the plan view!
Some project templates (especially the kanban project) use other statuses and mess this up thereby...
