I have a Team-Managed project which shows each Key without a strike-through.
When a filter is created for this same project, a strike-through is displayed on the project Key for 2 Statuses.
How can I remove the strike-out formatting?
Hello @Julia R_
Can you provide some screen images to show us what you are seeing?
Strike through typically appear when an issue is changed to a green/done status and the Resolution field is set.
Thank you, @Trudy Claspill
Attached are 3 screenshots
Ideal Results for each Status regarding Strike-through:
