Project Key Reuse Inquiry
Roxsanne November 6, 2023
When you archive a project, can you reuse the project key? For example, if we have a project named 'Technical Operation 2023 Q4' with the key 'TO' and we archive it, can we then create 'Technical Operation 2024 Q1' with the same key 'TO'? Thanks.
3 accepted
Laurie Sciutti
Hi @Roxsanne ~ previous replies are accurate.  My question would be:  why would you want to create new projects based on quarterly work?  Why not use Epics (or releases) to track that so all Tech Ops work is tracked within the one project?
Murat Seven
November 6, 2023
Hi @Roxsanne thanks for your question.
You can following link might help.
The only way to reuse a project key would be if you delete the existing project. Once you use a project key, it is tied to that project.
Best,
Murat Seven
Roxsanne November 7, 2023
thank you
Jehan Bhathena
Hi @Roxsanne ,
You cannot reuse the Project key if the Project is archived.
Archived project issues can still be searched and thus they existing key cannot be reused.
An old answer that might help for reference : https://community.atlassian.com/t5/Jira-questions/Is-there-now-way-to-reuse-a-Project-Key-on-a-new-project/qaq-p/1073771#M342641
Jehan Bhathena
Hey @Roxsanne ,
If anyone of the threads helped you find your answer, please can you mark the answer as Accepted. It will help make the answer more visible to the rest of the community.
