Project Management & PMO
Andy Rosengard
Good day,
I am starting a PMO and I want to use Temp (Structure Cloud) as the product to establish a PMO. I have Structure Coud loaded but no clue how to get started.
Can someone walk me through the steps?
Thank you
Andy Rosengard, PMP, SAFe 5, CSM, ITIL 4
512-761-2007
3 votes
Valerie Knapp
May 24, 2024
Hi @Andy Rosengard , thanks for your question.
If you are asking for hands-on support, this is typically something an Atlassian Partner would provide, at a cost, as consultancy.
To set up Structure yourself, I would encourage you to contact the vendor of Structure to ask them for support - https://marketplace.atlassian.com/apps/34717/structure-ppm-jira-portfolio-project-management-tempo?hosting=cloud&tab=support
Here is a link to the documentation to help you get started / learn more about the tool - https://marketplace.atlassian.com/apps/34717/structure-ppm-jira-portfolio-project-management-tempo?hosting=cloud&tab=support
Cheers
Dave Rosenlund _Trundl_
@Valerie Knapp is correct, @Andy Rosengard. I will add that, the Structure Documentation has lots of good getting started help And the support team at Tempo will gladly help you get started.
Beyond that, Tempo has an excellent solutions engineering team that can help you even further.
If that’s not enough, as Valerie says, you can engage an Atlassian solution partner to help you with implementation.
Best of luck to you,
-dave
Like Valerie Knapp likes this
