Did anyone why use Advanced Roadmaps in a agile hybrid project? I would like to add the milestones and tollgates related to the project life cycle.
Thank you and regards,
Eric
I use Advance Roadmaps for all of my projects - I find it's a much better view of what's going on in a project or program and easier for business users and project stakeholders to understand.
I like to create a version in the project to mark stage gates and milestones on the Advanced Roadmap:
If you create a version as above, and then select 'highlight on timeline' it will give you a line to represent your milestone or stage gate:
Hi @[deleted] welcome to the Atlassian community.
Please be informed, Jira can be customized as per user needs, be it a simple, complex or hybrid projects.
All that I would say, is how you are defining your Jira workflows, requirements and projects you want to have visibility.
I would request you to have a look at advanced roadmaps guide for your planning and decision making.
