Hey guys, I am currently using Jira Work Management for projects managing. This is super user friendly and easy to use. However, I cannot able to get to know how much is the % for the overall project's progress. Does anyone know how to do or need to add on something?
Thank you.
Hello @Jesling Saw
Welcome to the Atlassian Community!!
Please correct me if I understood your question correctly, I am assuming that Project progress is related to sprint progress.
Yes, you can track the sprint progress in Jira. You can also see % (percentage) of the work/task is completed or how much task is pending.
On the left sidebar, in your Jira project, there is the option of Reports.
OR
You can add the following gadgets in your dashboard Sprint Burndown Gadget or Days Remaining in Sprint Gadget.
Let me know in case of any further help.
Prashant Sultania
Note: Upvote, Like or Accept Answer if it resolves your query
Hey Prashant, you are right! However, I do not get you on how to set the dashboard for Sprint Burndown Gadget. Basically, I would like to track on the project progress how many % are completed and how many % are in progress. I understand that it works on Reports but do I need to set anything in this case?
Looking forward to hearing from you again.
Thank you.
Once I am at report -> time tracking report -> what i got are all blank without any time or percentage shown, you may refer to the picture attached below.
