Project Role 'atlassian-addons-project-access' is not available in project settings -> People
Girish Jagdale
All Project Roles (Settings -> System -> Project Roles) can be viewed in People section of Project Settings but not 'atlassian-addons-project-access'. Why it is so?
Gregor Kasmann_Actonic
December 25, 2017
atlassian-addons-project-access is a special Role, used for add-ons restrictions only. You cannot add some user to this role thru "People" menu:
More details https://confluence.atlassian.com/servicedeskcloud/blog/2017/02/add-on-permissions-update
Girish Jagdale
Thanks Gregor!
Loli_ola January 28, 2020
is it possible for someone to delete this role, as I can't find it on Jira hence can't connect to Jira Service Desk
December 25, 2017
At first check that you have this role /secure/project/ViewProjectRoles.jspa
Then you should be able to use it in your permission scheme:
Girish Jagdale
It is available there (and i guess it's by default) in System -> Project Roles. But not at project level when we check from Project Setting -> People where we can assign the role to users
