×Hello everyone,
In which project can a user have a role or not, can I see it on a single screen?
I will give a new user the same role as another user, but it is very difficult to enter all the projects one by one.
Or is there a plugin? (free)
Sample;
baris.ozer has an admin role in 15 projects if there are 100 projects.
Hi @Barış Özer , adding users and/or groups to project roles needs to be done on a project by project basis (unless you make it a default member of a project role)
There is a third-party apps available, but it isn't free: Project Roles - Groups and Users
Thank you for the quick reply.
I want to ask one more thing about powers.
The user can see the INF project even though he has no role in the INF project.
I'm looking with permission helper, it doesn't have permission. How is it?
Attached are the details.
Can you help?
Merhaba @Barış Özer ,
For the usage of Project Roles - Groups and Users app, I can help if you contact me over support@bloompeak.io. We can double check the permission with our app.
