why does "No project could be found with key" shows up when the project can be located in database in Jira.
I created a project through scriptrunner post function in Jira and can see it in the UI list of projects. But when I try clicking on the Project, it says "No project could be found with key". I checked the backend and it shows the project details of that project_key in the project table in database.
What could be the reason and how can I fix this issue. Any help please?
It could be that you are not a member of the Browse Permission in the Project Settings -> Permissions of the newly created project that is why you can't see it.
Wait how did you check the database? You are using the cloud version right?
Hi @Anshu Raina ,
Your tags to this question mention cloud but you checking in the database leads me to believe you are on a server version?
You say you created the project through a Post Function, did you also do a re-index after creation? That often helps in UI vs DB issues.
