×Hello,
we want to split a classic software project into 2.
Therefore, we have created a new classic software project (Auth) and moved some of the issues from the old project (Ethics) to the new one.
Problems now are:
Seems we have an interdependency between the 2 projects which we are not able to resolve or get rid of - even not with our internal Jira administrators.
Could you pls help here?
Thank you in advance!
Hi @[deleted] ,
is it maybe because the Auth Scrum board used for your sprint has a filter that has issues from projects Auth and Ethics ? I would first check that the Auth filter for your board is only setup for this project.
Let me know if this helps,
--Alexis
Hello @[deleted]
Welcome to the community.
With regard to your first bullet point, JIRA will attempt to automatically generate a sprint name based on the last sprint name shown in the board. In the new project, if it is showing a last sprint named "Ethics...", then when a new sprint is created it will default the name to "Ethics..."
With regard to your other bullet points:
A Sprint will show up in a board for either of the following reasons:
As you said, you had one project (Project A) and you have moved some of the issue in it to a new project (Project B).
Let us say you were in the board for Project A and you had created a sprint - Project A Sprint 1.
Let us say that sprint - Project A Sprint 1 - had Project A issues A-1, A-2, and A-3 in it.
Let us say that you moved Issue A-3 to Project B, but left it assigned to Project A Sprint 1.
Project A Sprint 1 will show up in both projects' boards. It will show up in Project A's board because it meets both of the conditions specified above. It will show up in Project B's board because it meets condition #2.
It is still just one sprint showing up in both boards. If you change the name or goal of that sprint in either board, that change will show in both boards.
