Sorry,
I am a beginner with JIRA and have the following problem:
The documentations says
Using the Wiki Style Renderer in the project description: You can use the Wiki Style Renderer to display rich text (HTML) in your project description.
but if I type
{color:red}
This is the Project Description
{color}
in the description Field the text will not be displayed red but the tags will be in d´the description as well.
In wiki style renderer mode there are two tabs below on the fields. (Visual and Text)
You can use this style in Text Mode.
Thank You very much Mesut, but unfortunately I have no tAB#s in the projekt description field.
I think my JIRA version ist much to old - I should have known. :-(
