I created a new project in my Jira instance. This second project appears (HMFND). However, when I try to open the Classic task board the project disappears. Only the original project appears (WAY).
If I do a search for issues, the project and issues appear, but the moment I change from the common view to the classic view the project completely disappears.
Any suggestions woould be great, as my team uses the classic board to follow and burn tasks..
You might not have enabled your new Project in the Greenhopper Configuration panel. In order to do this, you need Administration access.
You should be able to see you project now.
Thank you.. that worked like a charm....
