Project list is empty after upgrade to 6.2 on Jira Home
Jamie Johnson
February 26, 2014
I've recently moved from 4.2 to 6.2 and after doing so everything appears to have worked except when I am on my Jira Home (default) clicking on any of the menu items (Dashboards, Projects, Issues) they are empty. If I navigate to a specific project page these menu items have the content I would expect in them. How do I go about addressing this issue so the correct information is listed on these views?
Jamie Johnson
February 26, 2014
I ended up blowing the updated db away, clearing jira home and starting over and that resolve it as well.
JohnA
February 26, 2014
Hi Jamie,
From the sounds of it there's most likely a problem with the index, post-upgrade, so I would recommend that you try following the instructions in the resolution section of this document to completely rebuild the index as I'm hopeful this will resolve your issue: https://confluence.atlassian.com/display/JIRAKB/Unable+to+Rebuild+JIRA+Index
All the best,
John
