We would like to enhance capabilities of our Jira instance - we arre currently looking for Project Management module that would integrate seamlessly with core. Can you recommend antything worth of noticing? Regards, Lukasz
A and B are built in.
C is there, but define "very good" (also note that CSV is primitive and Jira exports RSS, XML and can respond to REST for much better detail)
D - you'll need a plugin, as Gantts are not really well suited to Agile and Jira is aimed more at Agile. There are several in the marketplace
E - depends on how you want to do that, but there's quite a lot there already and some excellent plugins for it as well (Folio is one that springs to mind, but it's worth trying for yourself)
F - Jira is an issue tracker. You probably want to look at Confluence for that. With the Questions add on ideally
G - again, a little vague, but there's quite a lot of plugins that do timesheet or progress reports on the back of the estimate functionality
We'd like to have:
a) Assigning task to people and move the task between team
b) Time tracking
c) Very good csv export
d) Gant diagram
e) View of many project and programs ( portfolio
f) Wiki/knowledgebase
g) Project tracking ( time, cost schedule) not ongly agile
you should specify your requirements. So we are able to give you better recommendations.
