I'm looking for advice on creating a project management board using JIRA. The goal is to have a Gantt chart, with dependencies, that depicts the entire process of a go to market plan, from engineering to customer support to marketing.
We want to have one place for everyone to see the status of tickets, tasks, etc. for 1 epic.
We also want to be able to do the following:
What report or apps would you recommend to accomplish this?
Hi, @Lauren Hogan. You may want to consider Advance Roadmaps, from Atlassian, which comes with your Cloud Premium subscription. However, it comes with a "Gantt-like" timeline. I am not sure it will meet the needs you outline.
You can also search Atlassian marketplace with this search:
https://marketplace.atlassian.com/search?category=Project%20management&hosting=cloud&product=jira
or this one:
https://marketplace.atlassian.com/search?hosting=cloud&product=jira&query=Gantt
Full disclosure: I work for one of the companies that develops a couple of the apps that will show up in those searches (Structure + Structure.Gantt).
I hope this helps,
-dave [ALM Works]
You bet. Good luck!
Let us know you decide to look at Structure + Structure.Gantt. We'd be happy to assist you along the way.
-dave [ALM Works]
@Dave Rosenlund _Trundl_ I'm testing using Structure + Structure.Gantt! Is there a way to get support while setting up an initial Gantt chart?
Hi, @Lauren Hogan . You bet.
By email (gantt at almworks dot com) or through our support portal.
Operators are standing by ;)
-dave [ALM Works]
You may have a look at another plugin mentioned in the list from the link - BigGantt. The plugin is bi-directionally synchronized with Jira, and changes are reflected in real-time. Moreover, you can adjust a view to, e.g., only unresolved issues or switch between views using defined Quick Filters.
