Project not associated with default permissions or notification schemes
Mike Smart
May 24, 2019
Hi folks, I'm not an expert on Jira but it seems project hasn't been associated with the Default permissions and notification schemes. I'm struggling to find a way of assigning the project to these schemes.
I'm an administrator for the project but alas that doesn't seem to make a difference.
Any help/hints would be appreciated :)
A lot of the documentation mentions an actions dropdown in the project settings, but I don't have that either.
Mike Smart
May 24, 2019
Thanks Venkatesh for the quick response.
I think I know the reasons for my issue.
When the the project was first setup it was done as a next gen type projects and not the classic style.
I created a new project, using the classic template and I'm getting what I expect.
Many thanks,
Mike
Olga Videc
Hello @Mike Smart
First can you open project settings?
When you open project settings you get something like this
Image result for project summary jira
In the middle of projest summary on the right side, beneath Roles, you will find permission and beneath that notifications
Under permissions, there is a scheme click on that
 The current scheme will open
In the top right corrner, you will see Actions click on that and there you will see use a different scheme.
Same goes for notification scheme
BR, Olga
