Project re-index
Lauren Brooker October 6, 2015
I was looking through previous questions and came across re-indexing projects.
I presume you would re-index a project the same reason you would for the whole of JIRA when making configuration changes i.e. updating add ons etc.
I just wanted to ask if re-indexing projects should be done often? And is there any other reasons to why you would re-index a project?
Lauren
Boris Georgiev [Appfire]
October 6, 2015
Normally you should not need to re-index anything as JIRA handles index updates on every issue operation. The articles below provide some details on indexing and when you should manually trigger re-index:
https://confluence.atlassian.com/jira/re-indexing-after-major-configuration-changes-198246923.html
https://confluence.atlassian.com/jira/search-indexing-185729671.html
Nic Brough -Adaptavist-
October 6, 2015
I tend to use it when you're messing with the field contexts that are related to single projects mostly.
Mihamina Rakotomandimby
To my understanding, indexes are updated when issues are updated.
Then, if you dont change configuration, or if you dont manipulate the cache directory, you dont need to launch a reindexing process.
On my hosted instance, i switched the cache directory to ramFS and need to reindex after reboot.
Cheers.
David Dunaway October 6, 2015
Is there a way to force a  re-indexing to occur via the REST API? I see that you can do a "api/2/reindex/request" .
My use case is when we failover to our standby JIRA instances and need to re-index, can I simply issue that API call and force a re-indexing to occur, or would I need to do someother manual task to force a re-index (ie: from the UI as an adminstrative user).
Thanks!
