×Hi,
Is there a clean way to achieve the functionality in which certain issue types can be created by users in certain roles?
The only way i can think of is putting conditions on create transitions, is there any other way?
I have implemented this feature using a groovy script on the create issue validation phase.
Consider this: https://marketplace.atlassian.com/plugins/net.youngaweb.jira.issue-type-ui-filter. I recently released it. This is client side only, but are working on a server-side check as well.
as of my knowldge you can't add condition to create transition!! only you can configure validators and postfunctions!
you can find workaround here
https://jira.atlassian.com/browse/JRA-5865
https://answers.atlassian.com/questions/33259/permission-to-create-specific-issue-type?page=1#33270
my bad, yes i meant validators on create transition. I can use groovy script to achieve this functoinality using the scripting plugin.
