Project role mapping with issueType
Tarun Sapra
Is there a clean way to achieve the functionality in which certain issue types can be created by users in certain roles?
The only way i can think of is putting conditions on create transitions, is there any other way?
Tarun Sapra
I have implemented this feature using a groovy script on the create issue validation phase.
Young Plugins
Consider this: https://marketplace.atlassian.com/plugins/net.youngaweb.jira.issue-type-ui-filter. I recently released it. This is client side only, but are working on a server-side check as well.
RambanamP
September 23, 2013
as of my knowldge you can't add condition to create transition!! only you can configure validators and postfunctions!
you can find workaround here
https://jira.atlassian.com/browse/JRA-5865
https://answers.atlassian.com/questions/33259/permission-to-create-specific-issue-type?page=1#33270
Tarun Sapra
my bad, yes i meant validators on create transition. I can use groovy script to achieve this functoinality using the scripting plugin.
