We know that we can add custom fields for Issues.
But is there any way to add custom fields for projects?
Hello @Nitin Makwana
I would recommend checking our solution for Jira, which is the perfect solution for what you are looking for, and it might add more value in order to visualize and organize your projects in Jira.
Take a look >> https://marketplace.atlassian.com/apps/1210816/profields-jira-project-custom-fields?hosting=datacenter&tab=overview
And you can contact the vendor for further information on their website >> https://www.deiser.com/contact-us
I hope it can be helpful for you!
I'm sorry to say that you don't have any option to create project custom fields.
You can check this issue for the progress on that and some workarounds
