At my organization all new client projects begin with a series of administrative tasks like creating a Slack channel an setting up a Jira Kanban project. How can I set these up in a template once so I can save the need to create this group of tasks with each new project?
Hi Shawn,
I do have the same scenario and I'm using JWT plugin. that helps me creating predefined task automatically.
If you do not want to use plugin, then have a csv file ready with the task details. And create New Project using Import Project option.
Here is more info about it : https://confluence.atlassian.com/adminjiraserver073/importing-data-from-excel-861253688.html
Hope it helps
Amit
Thanks Amit. Ideally I’d only need to set this up once until the tasks change. I’ll check out the JWT plugin.
