Project type: Is there a way to identify the 'Project Type' of an existing JIRA installation?
Cibi Cherian October 24, 2013
I am trying out an local installation in my windows PC to get familiarised with the JIRA administartion before actually laying my rookie hands into the official installation. i want to select the same project type as the official Installation type. Where can I find the project type in the already installed JIRA [Yes I have admin account]
Bharadwaj Jannu
October 24, 2013
do you mean Project Category?
Bharadwaj Jannu
October 24, 2013
Yes I got now
Bharadwaj Jannu
October 24, 2013
reading the Udo Brand's answer and seeing the snapshot in Simple heading of http://blogs.atlassian.com/2013/05/meet-new-jira-6/ my mind glown.
I think the project types have no full fledged implementation yet. Check Natalie's comment in https://answers.atlassian.com/questions/188911/what-is-the-difference-between-project-types
Bharadwaj Jannu
October 24, 2013
yes, for practicing purpose select a Blank Project option. Once you get practised yourself come to know.
Udo Brand
October 24, 2013
From what I saw in the documentation, the differences between the project types is the implemented workflow (and even that is not completly correct). So check which workflow is implemented. However this will not work if the workflow was replaced.
I guess the project type is not that important at all. Try to implement on your PC installation the same workflow -, issue type - , screen -, field configuration schemes in order to figure out how this works.
Good luck
Ok learnt from @Bharadwaj's reply that the Project types doesnt have any functionality[ at least till September :)]
JIRA is asking me to slect the project type when first time configuring ..
PFA screen shot.
Bhushan Nagaraj
October 24, 2013
Hi Cibi
Not exactly sure what you mean by project type and the above line. Are you looking for a demo project? What version of JIRA are you using?
Have you tried creating a demo project.
Renjith Pillai
October 24, 2013
What do you mean by project type?
