Push key name from Jira to salesforce field using Salesforce & JIRA Cloud Connector
Laura Hackett
July 10, 2018
We want to push/pull the key name of a Jira Issue onto a salesforce field. (The same object that creates the ticket)
Is this technically possible and what would be the steps on the Jira and Salesforce admin side
Kevin Lew [ServiceRocket]
Hello Laura,
Are you referring to push Jira issue key to Salesforce custom field?
If yes, it is possible to do that.
Here are the steps:
  1. Go to Jira > Salesforce > Bindings > Your Bindings > Click on Mapping > Locate the issue type that you want to map > Click on Mappings > Add *Key* field and Salesforce custom field > Save.
For example:SS1.PNG
Please note that Jira key is Read-only field. Please ensure that you make the sync direction Outbound only (Jira to Salesforce). The screenshot above is an example that you can refer to.
Hope this helps you.
Laura Hackett
July 11, 2018
Thanks so much! That helps a lot.
