We have a problem with saving priorities for TC. I set the priority, see Figure _qaspace.PNG
For a moment, it seems that everything is ok.
Once I jump to another page, or TC assign to any plan, so the priority is set back to the default level. It looks, This field is not saved anywhere and it is different from stand Do you know where the problem could be
In our company we have operated JIRA on your own server.
Tomas Hak
tomas.hak@ecommerceholding.cz
Hi Tomas,
we are aware of this issue and have already implemented the solution for that (you will be able to set any Priority statuses that is configured in JIRA admin page).
The release of the feature will be available on one of our next releases. Hopefully on the upcoming one scheduled on the next week.
Kind Regards,
Laszlo
Hi Laszlo,
This issue is also occuring for Test Case import from excel as well. Can you please check on it?
Do let us know whether the above fixed issue will work for importing test cases from xls file as well?
Kind Regards,
Uday
Hey,
Thanks for the reminder - we will re-test import as well.
The bug is fixed already, it will be included in the next release. Please bear with us until then.
Thanks: Laszlo
