Querying for versions past due
Tanner Wortham
August 30, 2012
From what I can figure, JQL isn't powerful enough to give me a list of fixversions across all projects that are unreleased and are past due. I would like to create a subscription so others emailed this result set on a periodic basis.
If I'm mistaken, I hope someone can set me straight. If I'm correct, does anyone have a work around to get this information another way? An answer free of custom code and money is preferred. ;)
Jobin Kuruvilla [Adaptavist]
August 30, 2012
You can get all versions that are in unReleasedVersions but not based on release date (due date). Not without custom code or money I guess ;)
August 30, 2012
lol. Btw, I guess you are missing a small detail. Issue Navigator and JQL can return only issues. Nothing else. You can have JQL functions that return versions etc but that can only be used in searching for issues.
Tanner Wortham
August 30, 2012
from what i see, even that doesn't get me a list of versions. it instead gives me a list of issues that are included in unreleased versions. you can't have my money, jobin! ;)
