Question on JIRADB using postgresql
jananeev September 25, 2013
we are connecting JIRA to postgresql.
Issue:
In jiradb database,while querying jiraissue table,pkey column values(ie issue keys for each issues) are not displaying.
Query: select * from jiraissue;
we have cross checked the above table jiraissue results by connecting jira with mysql, its dispalying pkey column values (ie issue keys).
Could anyone please help on the above issue ,why pkey values are not inserting in jiraissue table when connecting through postgresql.
3 votes
JamieA
September 25, 2013
Are you using jira 6.1? The data from that column has been removed, see https://developer.atlassian.com/display/JIRADEV/Preparing+for+JIRA+6.1#PreparingforJIRA6.1-editprojectkeydb
(Nothing to do with postgres).
yes IM USING JIRA6.1, BUT THROUGH MYSQL ITS CONNECTING.THEN WHICH VERSION OF JIRA HAS THAT COLUMN?
Nic Brough -Adaptavist-
September 25, 2013
Ouch, shouty.
Version 6 and below still have that column. You should read Jamie's link to see what is changing here.
Thank you..Sorry im new to jira.am not aware of this
jananeev November 4, 2013
I want to import JSON file for importing link information in JIRA 6.1.
In previous version ,JSON file had src and destination key as pkey(issue key).
If that column(pkey) is empty in JIRA 6.1 ,what will be values for src id and dest id in JSON file?
MichałS
September 25, 2013
It is a good practice to use the search option first...
https://answers.atlassian.com/questions/215873/where-is-pkey-store
