R4J - Reuse of Requirements in the same project
Ann Rang
December 11, 2019
is it possible to reuse requirements within the same project? The guideline says that "This option is only enabled if the destination is in a different project.", but it would be great, if we could reuse the requirements.
Is there a possibility?
Thank you for an answer.
Best wishes, Ann
Bernhard Doleschel (Ease Solutions)
January 27, 2020
Hello Ann,
to keep the structure and setup within one Jira project as simple as possible, you can´t reuse an issue in a project twice. Sorry for this limitation.
If you have more or other questions, please don´t hesitate to contact our support team: https://easesolutions.atlassian.net/servicedesk/customer/portal/2
Best regards, Bernhard, ease solutions
