×Hi,
While I understand these are not documented APIs I think you used to be able to get the branches associated with an issue using a call like the following:
https://alterian.atlassian.net/rest/dev-status/latest/issue/detail?issueId=119044&applicationType=bitbucket&dataType=branch
This issue has a linked commit to a particular branch so I was anticipating that this call would return that branch.
Has this changed - and if so, is there any other way to get the branch information
Hi @Paul Becker ,
Even if it is an internal endpoint it still works fine. It's just that you should use details instead of detal:
https://XXXXX.atlassian.net/rest/dev-status/latest/issue/details?issueId=10196&applicationType=bitbucket&dataType=branch
Please use 'details' in the endpoint you are calling and confirm this works.
Dario
Hi Dario. Thanks for your reply.
Using details rather than detail does give me a bit more information about the commits but still doesn't include any branch information - unless I also have a linked pull request.
As it stands I guess I would need to take the commit id and look up the branch via bitbucket, but I think you used to get the branch info directly in the branches array?
"errors": [],
"detail": [
"branches": [], -- I think this used to be populated when you had an associated commit
Paul
Hi @Paul Becker ,
I am not sure I understand correctly, but I can see branches information being returned whether I use the endpoint
/rest/dev-status/latest/issue/summary?issueId=
OR:
Example:
curl -v -u <EMAIL-ADDRESS>:<API-TOKEN> "https://<NAME>.atlassian.net/rest/dev-status/latest/issue/details?issueId=10196" | json_pp
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 10391 0 10391 0 0 5668 0 --:--:-- 0:00:01 --:--:-- 5668
"errors": [
"detail": [
"branches": [
"name": "feature/KFF-39-test",
"url": "https://bitbucket.org/{}/{edcb945a-5aee-XXXXXXXXXXXX}/branch/feature/KFF-39-test",
"createPullRequestUrl": "https://bitbucket.org/{}/{edcb945a-XXXXXXXXXXXXXX}/pull-requests/new?source=feature/KFF-39-test",
"repository": {
"name": "New_repo1",
"avatar": "https://bytebucket.org/ravatar/%7Bedcb945XXXXXXXXXXXXXXXX7%7D?ts=default",
"url": "https://bitbucket.org/{}/{edcb945a-5aee-44XXXXXXXXXXXX06d07}",
"commits": [
"lastCommit": {
"id": "2847fb7981b1b0e0XXXXXXXXXXXX88085f4",
"displayId": "2847fb7",
"authorTimestamp": "2020-02-12T13:15:15.000+0000",
"merge": false,
"files": [
OR:
curl -v -u <EMAIL-ADDRESS>:<API-TOKEN> "https://<NAME>.atlassian.net/rest/dev-status/1.0/issue/summary?issueId=10196" | json_pp
100 1116 0 1116 0 0 2364 0 --:--:-- --:--:-- --:--:-- 2359
"errors" : [],
"summary" : {
"deployment-environment" : {
"overall" : {
"showProjects" : false,
"successfulCount" : 0,
"count" : 0,
"lastUpdated" : null,
"dataType" : "deployment-environment",
"topEnvironments" : []
"byInstanceType" : {}
"branch" : {
"bitbucket" : {
"name" : "Bitbucket Cloud",
"count" : 1
"overall" : {
"count" : 1,
"dataType" : "branch",
"lastUpdated" : "2020-02-12T14:15:15.000+0100"
Can you kindly perform the same tests, share what you get and provide a bit more details on what would you expect to see instead?
Dario
Hi Dario,
Maybe I am misunderstanding now a branch gets linked to a JIRA issue. I had assumed that a linked commit would also cause its branch to be linked? Do I have to do something extra to link the branch?
I get the following:
{"errors":[],"detail":[{"branches":[],"pullRequests":[{"author":{"name":"Tim Shire","avatar":"https://secure.gravatar.com/avatar/94aa4d7ae2f0369ec1ba193d5bbd293d?d=https%3A%2F%2Favatar-management--avatars.us-west-2.prod.public.atl-paas.net%2Finitials%2FTS-1.png&size=48&s=48"},"id":"220","name":"dev-800 Initiatives API's (Create / Get / Edit / Delete)","commentCount":0,"source":{"branch":"feature/dev-800","url":"https://bitbucket.org/{}/{d4907970-2144-4d6a-9e4a-d14f89eac08a}/branch/feature/dev-800"},"destination":{"branch":"master","url":"https://bitbucket.org/{}/{d4907970-2144-4d6a-9e4a-d14f89eac08a}/branch/master"},"reviewers":[{"name":"Paul Becker","avatar":"https://secure.gravatar.com/avatar/55daf92e9d032ca50ba85aca6fbea6c6?d=https%3A%2F%2Favatar-management--avatars.us-west-2.prod.public.atl-paas.net%2Finitials%2FPB-6.png&size=48&s=48","approved":false}],"status":"DECLINED","url":"https://bitbucket.org/{}/{d4907970-2144-4d6a-9e4a-d14f89eac08a}/pull-requests/220","lastUpdate":"2020-02-19T10:01:50.524+0000"}],"repositories":[],"_instance":{"singleInstance":true,"baseUrl":"https://bitbucket.org","name":"Bitbucket","typeName":"Bitbucket Cloud","id":"bitbucket","type":"bitbucket"}},{"repositories":[{"name":"Campaign Manager","avatar":"https://bytebucket.org/{}/{d4907970-2144-4d6a-9e4a-d14f89eac08a}/avatar","url":"https://bitbucket.org/{}/{d4907970-2144-4d6a-9e4a-d14f89eac08a}","commits":[{"id":"16c77aa90ef9ef5719d818b140ade0c930f53a5e","displayId":"16c77aa","authorTimestamp":"2020-02-17T11:13:38.000+0000","url":"https://bitbucket.org/{}/{d4907970-2144-4d6a-9e4a-d14f89eac08a}/commits/16c77aa90ef9ef5719d818b140ade0c930f53a5e","author":{"name":"Paul Becker","avatar":"https://secure.gravatar.com/avatar/55daf92e9d032ca50ba85aca6fbea6c6?d=https%3A%2F%2Favatar-management--avatars.us-west-2.prod.public.atl-paas.net%2Finitials%2FPB-6.png&size=48&s=48"},"fileCount":1,"merge":false,"message":"DEV-800 Add new stored procs to project\n","files":[{"path":"Database/Database.sqlproj","url":"https://bitbucket.org/{}/{d4907970-2144-4d6a-9e4a-d14f89eac08a}/commits/16c77aa90ef9ef5719d818b140ade0c930f53a5e#chg-Database/Database.sqlproj","changeType":"MODIFIED","linesAdded":6,"linesRemoved":0}]}]}],"_instance":{"singleInstance":true,"baseUrl":"https://bitbucket.org","name":"Bitbucket","typeName":"Bitbucket Cloud","id":"bitbucket","type":"bitbucket"}}]}
and for:
https://alterian.atlassian.net/rest/dev-status/latest/issue/summary?issueId=115254
"errors":[],"configErrors":[],"summary":{"pullrequest":{"overall":{"count":1,"lastUpdated":"2020-02-19T10:01:50.524+0000","stateCount":1,"state":"DECLINED","dataType":"pullrequest","open":false},"byInstanceType":{"bitbucket":{"count":1,"name":"Bitbucket Cloud"}}},"build":{"overall":{"count":0,"lastUpdated":null,"failedBuildCount":0,"successfulBuildCount":0,"unknownBuildCount":0,"dataType":"build"},"byInstanceType":{}},"review":{"overall":{"count":0,"lastUpdated":null,"stateCount":0,"state":null,"dueDate":null,"overDue":false,"dataType":"review","completed":false},"byInstanceType":{}},"deployment-environment":{"overall":{"count":0,"lastUpdated":null,"topEnvironments":[],"showProjects":false,"successfulCount":0,"dataType":"deployment-environment"},"byInstanceType":{}},"repository":{"overall":{"count":1,"lastUpdated":"2020-02-17T11:13:38.000+0000","dataType":"repository"},"byInstanceType":{"bitbucket":{"count":1,"name":"Bitbucket Cloud"}}},"branch":{"overall":{"count":0,"lastUpdated":null,"dataType":"branch"},"byInstanceType":{}}
Paul
Hi @Paul Becker ,
As written in the Referencing issues in your development work documentation page, in order to have a branch linked to a Jira issue you have to include the issue key in the branch name.
For example, in my case you can see:
"branches": [
We do have the below feature requests open in our system to add the possibility to link already existing branches or to be able to link a branch without having to include the issue key in its name but they haven't got much traction so far:
You may want to vote and watch the above feature requests so that you will get notified in case of any update. The features will be addressed according to the Implementation of New Features Policy
Also, for more details, you may want to review the below links:
Have a nice weekend.
Dario
Thanks Dario, but my issue name is in the branch name. I think it shows in the details trace above (via the source entry but not the branches item)
Hi @Paul Becker ,
The issue key in your branch name is lowercase while, as mentioned in the provided documentation pages, it has to be uppercase (same as in Jira).
Note that the issue key must conform to the default Jira key format – that is, two or more uppercase letters ([A-Z][A-Z]+
), followed by a hyphen and the issue number. For example, ABC-123.
In all cases, the issue key must use to the default Jira key format – that is, two or more uppercase letters ([A-Z][A-Z]+
Can you kindly change the branch name from dev-800 to DEV-800 and let us know if this works?
Dario
Thanks Dario, I noticed the same this morning and have managed to get a branch back :) - and now seem to be stuck on this issue instead!
https://community.atlassian.com/t5/Jira-questions/SDK-name-vs-displayName-userPicker-NullReferenceException-in/qaq-p/1303712
There don't seem to be any updates on this though :(
And it looks like there is a new alpha release to help work around the other issue. Once again, thanks for your help - and I guess I can close this now!
You are very welcome @Paul Becker and thanks for sparing some time to accept the solution.
I can indeed see that the new issue you are talking about was fixed as part of:
Federico Silva Armas REPO OWNER
Hello everyone, I have published a new alpha release that includes all fixes known to date: https://www.nuget.org/packages/Atlassian.SDK/12.1.0-alpha03.It includes documentation that shows how to use the feature: https://bitbucket.org/farmas/atlassian.net-sdk/src/gdpr/docs/how-to-handle-gdpr-changes.md (docs will be eventually merged to master).
Given this, I am going to resolve this issue. If you find any problems with the alpha release, please open a separate issue (use component ‘GDRP’ so I can manage them).
Also, for the future, please notice that:
If you meant to write an app for an Atlassian Cloud product then please see the following guides instead:
In order to get support on development related issues, please refer to the resources are listed in https://developer.atlassian.com/resources. Specifically:
I hope this helps.
I will now go update the other thread with this information as well :)
Dario
