Hey check Script Runner new library lot of cool stuff and sample scripts.
https://library.adaptavist.com/entity/round-robin-assign-issue-to-users-in-a-certain-project-role
Hi Miguel,
you won't be able to achieve that with a default Jira installation. Are you using Jira Server or Cloud?
If you're looking at available workflow apps on the marketplace for Jira Server you should be able to satisfy this need with a few of them. :) But what is your overall use case in more detail here? Do you really want to randomly assign issues to users in a project (Which means they need to have the"Assignable User" permission and do they have access to the project as well)? Or are you aiming at a round-robin assignment or least busy user?
Best, Max
What I know for sure is the following:
So these are two of a few more available options on the marketplace you can have a look at and investigate. With a groovy script, you should be able to achieve that with Scriptrunner and Jira Misc Workflow Extensions as well but that's something others have to answer. :) I'm pretty sure you can't do that with JSU. But as you can see, there are a few options available.
Best, Max
Hi Max
Thank you for answering my question,
Actively I work with Jira service desk projects.
He wants that when a tiket is created, it will be assigned as randomly to the person who has less assigned tickets.
Could it be?
