Hi guys,
I am using rapidboards and would like to view the content of past sprints, together with their burndown charts.
I've noticed that once I complete sprint it's gone and cannot be found anywhere.
I could crate a filter having "sprint=" in but do sprint name does not work. I guess it's sprint's ID I should enter but dunno how/where to find it.
What would you suggest?
Thanks in advance,
Aquarius.
Which version of GreenHopper are you using? If it's 6.1.x, you should be able to select past Sprints in the Report view, where the Sprint Report will display all Issues in the Sprint, and the Burndown Chart would be available as well.
As for looking for Issues in a Sprint in the Issue Navigator, you'll need to use the Sprint ID only, so just "86" instead of "Sprint 86" (unless you're on OnDemand, where looking up by Sprint name has just been implemented). You can get the Sprint ID by looking the URL in the Report view - there'll be a sprint=x at the end of it.
Go to Reports
With currerent sprint a drop down exist. Click on drop down and choose any sprint you want to go.
You can view all stories of a sprint
